I am having creaive SBS A320 speakers. but now there is np sound in woofer & speaker. when i showed this to local technician he told me there is I C problem no. TDA 8510 it is not available i the market. so kindly either tell me service centre details nearby me in Rohtak Haryana pin 124001 or please contact me to solve this problem. regards Pradeep Munjal Rohtak 09812660925
SOURCE: Advent ADE 210C
There is no easy way to tell you this. The smaller speakers usually plug into the large speaker. The large speaker is the sub and has a power source for the other speakers.
I
can't fix this for you, but if I helped you get it fixed, please rate it as a
fixya not a helpful rating. These ratings let me be allowed to help you
and others in the future.
SOURCE: 3 of 5 speakers not working.
normal stereo sound its not 5.1 if your hearing music its stereo and not in 5.1 channels, you need to activate the Creative Sound EAX sorround mix, check on the EAX console, there you can simulate 5.1 or clone the 2.1 channels to the rear speakers, i like more the simulation works better... simply sends some freqz to the rear speakers
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
SOURCE: Logitech THX Z-2300 Speakers Don't work and subwoofer does
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
SOURCE: CREATIVE SPEAKERS NOT WORKING!!!
creative speakers not working.even though power button on the led not glowing. today morning properly worked but suddenly not working light not glowing. send me solution to my mail [email protected] tan q
