Here is a manual for the Seiko Melody in Motion Wall Clock, Model # QXM123BRH:
Getting Started
- Insert one "AA" size alkaline battery into the clock's battery compartment.
- Set the clock to the correct time by pulling out the time-setting knob and turning it clockwise or counterclockwise to set the time.
- Push the knob back in to the "Lock" position to finish setting the time.
Melody Selection
- Press the "Demo" button on the clock's front panel to listen to all the available melodies.
- To select a specific melody, press the "Melody" button repeatedly until the desired melody plays.
Volume Control
- To adjust the volume of the melody, press the "Volume" button repeatedly until the desired volume level is reached.
Light Sensor
- The clock is equipped with a light sensor that will automatically turn off the sound and motion sensors when the room is dark.
- To disable the light sensor, push and hold the "Light Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
- To enable the light sensor, push and hold the "Light Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Motion Sensor
- The clock is equipped with a motion sensor that will detect movement in front of the clock and activate the sound and motion sensors.
- To disable the motion sensor, push and hold the "Motion Sensor" button for approximately 5 seconds until the "OFF" indicator appears on the display.
- To enable the motion sensor, push and hold the "Motion Sensor" button again for approximately 5 seconds until the "ON" indicator appears on the display.
Nighttime Silencer
- The clock is equipped with a nighttime silencer that will automatically turn off the sound and motion sensors during a designated period of time.
- To set the nighttime silencer, push and hold the "Nighttime Silencer" button for approximately 5 seconds until the "SET" indicator appears on the display.
- Press the "Melody" button to select the start time for the nighttime silencer.
- Press the "Volume" button to select the end time for the nighttime silencer.
- Push the "Nighttime Silencer" button again to save the settings and exit the nighttime silencer mode.
Troubleshooting
- If the clock does not operate properly, try replacing the battery with a new one.
- If the clock still does not operate properly, contact Seiko Customer Service for assistance.
Note: This manual is for general information purposes only and may not cover all features and functions of the Seiko Melody in Motion Wall Clock, Model # QXM123BRH. Please refer to the manufacturer's instructions for complete information on how to operate and maintain your clock.
