Nikon FE 35mm SLR Camera Logo
m
mischa de stroumillo Posted on Nov 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rewind button won't push down - Nikon FE 35mm SLR Camera
zdenek vajdak
Level 2:
Champion:
  • Expert 206 Answers
  • Posted on Nov 06, 2013
zdenek vajdak
Expert
Level 2:
Champion:
Answers
206
Questions
0
Helped
90456
Points
353
On the ASA dial ( left side of the camera ) there is a small lever that can be moved up and down. Try moving it and while you hold the lever in the up position press down the rewind knob which should move down.
How do you rewind while dictating with the Olympus DM 620?
To rewind, you simply push the rewind button. However, this does not rewind from the point you are at like a tape does, it goes to the beginning of the recording. Once you are in the play mode, pushing rewind will rewind from that point.
Nikon f601 won't rewind
needs repairing at a qualified shop
The play, rewind switches won't stay down
I have advised people before that replacing belts is not the only answer and sometimes people that are not experienced can upset some part of the deck without knowing it. We don't yet know the model or brand of the unit and from the description this kind of points to a Piano key or lever key type deck. I could also be a cam system deck. This complaint of buttons not staying down would not apply to a tack switch or solenoid type transport.
Like Jerry says a visit to a good Tech is the answer. I have been doing tape decks for 40 years and have worked at Sony and Teac service shops. If you need my help let me know. I am near Chicago.
8helpful
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
7helpful
2answers
How do u set the clock in a 1998 Ford Expedition?
push the clock button with the radio off and key on,then hit the fast forward and rewind to adjust the time
4helpful
How do I set the clock on my aiwa cx-N990 desktop stereo?
-power on the stereo
-push the clock button
-press pause on the cassette deck - the hour should be blinking
-press fastfoward/rewind to adjust it up and down
-push pause again to move to minutes
-push ff/rewind to adjust minutes
-push pause one last time
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Kenmore progressive canister Sweeper
I figured it out ..by pushing the lever down and pry a screw driver into three different spots on the top, to release the rewind bar. Looks like three little j hooks hold it down. It took a flashlight and night time for me to see it.
Mar 19, 2008 • Vacuums
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
