I try to connect my ds lite and i get error messages after it says it has connection so how can i change the secruity to allow it
Try changing your WiFi encription to WEP or no security, this should be available on your cablemodem/router web internface (need a user and password for that) under the Wireless/Security option.
DS Lite is not compatible with any other WiFi encription for online gaming: "Important note about the Nintendo DSi and WPA security: While the Nintendo DSi is compatible with WPA security, Nintendo DS games with online play still require the use of WEP or no security to connect with the Nintendo WFC. Therefore, your connection settings for using these games must be set up on slots 1-3. If you need more details on using your adjusting your router's settings,click here and select your router (if available).
SOURCE: 2wire 2701HGV-W Gateway wi-fi modem
The 8200 by itself does not have networking capability.
This means that you cannot connect it directly to your router and give it an IP address, so others can connect to it.
The good thing is, that this printer is listed on the list for compatibility for upgrade with the wireless network kit (see here). The bad thing is - this kit costs about 70$ (see here).
A solution which does not cost anything, is to share the printer from
your computer with the other computers. The downside is that the
machine to which the printer is connected has to be running in order to
let the others print.
If you decide to buy the Networking Kit - here are the setup instructions.
Sorry - but there is no simple (plug & pray) solution.
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: error 51330 on nintendo wii siemens gigaset se587 wlan used.
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck, IAN.
SOURCE: I cant set up Wi-Fi connection on my SIEMENS SpeedStream 6520?
Here are the tips on how to setup your wi-fi connection.
www.yboyandrei.net/wifisetup
Hope this might be helpful to you.
SOURCE: I have a SURFboard SB5101 Cable Modem & I'm
Are you sure you have posted the right model. The thing is, a SURFBoard Cable Modem does not provide WiFi. You will need a router for that.
The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:
If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
