SOURCE: phone memory full
I had the same problem. The internal 160mb fills up even though if you use memory manager there's nowhere near that much data. The cure was simple enough, switch on your phone holding the green key, 3 key and * key at the same time - this will perform a total reset and flush the memory. Make sure you backup any data you want to keep to your PC or Micro SD card first - when it's gone, it's gone!
I also removed my 2Gb SD card to be safe when I performed the reset.
SOURCE: my e66 cannot send text messages....it shows the
sir your phone memory is full.empty your inbox and outbox and format your handset by using the following code *#7370#
it will require your phone lock code which is 12345 in default.
good luck
SOURCE: cannot send text message;memory full close some other application
firmware not firmfare.dude..you just need to reset your phone to send a message..*#7370#..hope will help you this idea..
SOURCE: Hi I am unable to send any text message...
please check your message center number in the message settings,it seems you will also need to fomate you phone this is the code *#7370#
SOURCE: My mobile will not send
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
