The error code should describe the problem. Since you didn't post the error message, look it up here:
https://www.lifewire.com/blue-screen-error-codes-4065576
SOURCE: acer aspire 5572 problem
your problem is called BSOD (blue screen of death).
many thing can cause this problem.
most common thing that cause BSOD are Operating system, memory and harddrive.
sometime motherboard+cpu can cause BSOD too, but not as often as memory+hdd+OS.
you should re-installed it first, if you still have BSOD,
ask your technician to check hdd and memory, if they can check motherboard + cpu, it would be good for you,
SOURCE: my laptop show blue screen
It sounds like it is time to reinstall Windows.
RIght after power on, tap either the F5 or F8 key (not always the same) to see if that will pull up a short text menu with different boot possibilitiesm, one of which might be 'Recover.'
SOURCE: How to remove a hard drive on a Sony Vaio Model PCG-9411
hi,
Can you please describe the model number as well ?
please check http://www.fonerbooks.com/laptop_9.htm if it can help you out.
thanks.
SOURCE: lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
SOURCE: Sony Vaio PCG-9H4L cannot find hard drive
you can try to go to bios pae and check if the system can detect the hard drive.If not you might need to call call Sony to check if the system is still on warranty so that they can replace the hard drive free of cost if not you might need to replace it with a new one
