SOURCE: whirlpool electric oven
does your unit have a button to open door or do you just pull it to open it they are sometimes really stiff at first if it is button then it will need lock replacing about 60 pound if it just pulls open then these can seem stuck but will open as there is no mechanism to open the door so it will open but might take a bit of force the first few times untill it wares in a bit so dont be afraid of using force as it will open post back if you have any trouble and i will find a manuall and see what it says in their ok hope this is some help.........................................
SOURCE: my whirlpool oven door is locked. After cleaning
HI. This will indicate that the door lock mechanism is damaged. follow the procedure below to address further.
If the door is latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If there is no damage to the wires and all connectors are okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
NOTE_ This will, normally, lead to the replacement of the door latch assembly.
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
This indicates the keypad or ERC electronic range control has failed.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
