Usually the SD card is a secondary storage device ... and separate from the (internal) phone memory. To determine / test this, see if your phone still have (some) information when you remove the SD card from the phone... e.g. your telephone contact list, etc.
Yes, you can try to recover the "deleted" file on the SD card using a PC / laptop ... using a data recovery utility/tool (on your PC) to scan the storage space or "undelete" that deleted file..
If your phone can be attached to a PC (e.g. via USB), and if your PC recognizes the "storage" disk on your phone as an "external" disk, you may also be able to use a data recovery utility to scan the storage space or "undelete" that deleted file.
SOURCE: Cannot copy files to "My memory" card
Hi there, l am going to try and show you how to get to your memory card step by step starting with one
1...connect your phone to your putter
2...click on explore in the Microsoft ActivSync box when it is finished synchronized
3...another window will pop up that is called Mobile Device
4...at the very top of the list Double click on...My Windows Mobile Device
5...in the next widow click on...My Storage
6...OK if you did everything the way l have told you...you are half way there
7...now what you do here is right click and make a new folder and call it.. Video or Music or Photo's
8...The rest is easy just open that folder and copy and paste what ever you want into it....
9...Like me, l made a folder for photo's and music and video's..make as many as you want
10...When you finish putting in all your music and video's and photo's into your folder's.. close everything and disconnect your phone from your putter
11...Now gab your phone and go click on Menu
12...then click on media album
13...then click on My Storage
14...there you go...all the folder's you made are there, just click on them to open them but remember if you click on your music folder make sure that you highlight the music note at the bottom of your phone screen or the file's will not show they are there...
15...The same is for video's and photo's, make sure you click the right image to what you want to view in that folder at the bottom of your phone......
16...To play a song or to view anything just click on it....
17...Well l hope l have solved everything for you, if you got this far down, good luck and all the best
SOURCE: Samsung j600 mobile phone MP3 player not playing MP3's
even adding individually did not work. i formatted memory card on pc,added tracks to it individually. bt of no use. my phone still shows an empty music folder which cannot be deleted..
SOURCE: file transfer problem from phone memory to micro sd SGH- D780
samsung D780 sucks when it comes to accessing the memory card. i have the same problem too.
SOURCE: how do i free up storage on my new samsung jack?
Open up Internet Explorer, hit menu>tools>options>memory
clear your temporary files. I just cleared over 4 MB that way
SOURCE: how to make memory card default storage of samsung GT s3310
Actually s3310 is slim and loaded with all facilities like mp3,Bluetooth and many more."We cannot change the default memory storage to memory card".I tested in all ways.
When the Bluetooth is on,we can transfer files only to phone and not to memory card.
If you want to transfer files with 1 gigabytes size,you have to split it up and transfer to phone and then to memory card.
