Get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
SOURCE: my 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
SOURCE: Chainsaw wen warms up bogs down, wants to die cutting into wood
Could be running too lean, Should be runnning 50:1.
SOURCE: Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
SOURCE: chain saw carburator settings for husqvarna 61
Turn both screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Allow the engine to warm up, then pull the throttle full on. Turn the H jet screw CW until the engine starts to speed up, but still 4-strokes. Proper adjustment occurs when the engine is 4-stroking, but immediately 2-strokes when cutting. This gives best power and lowest heat. Release the throttle and adjust L jet CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
SOURCE: my husqvarna 575xp chain saw starts and runs for
I had the same problem with my 575 xp and was able to correct it by cleaning the orange nipple that the gas tank breather hose connects to. The hole in the nipple is really tiny. I cleaned it out with a fine wire and then blew air through it.
