Sherwood RX-4105 Receiver Logo
Posted on Nov 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Output transistors current - Sherwood RX-4105 Receiver
Mike Charette
Level 3:
Genius:
  • Master 1,847 Answers
  • Posted on Nov 04, 2013
Mike Charette
Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490544
Points
2212
Check the numbers on the transistors.Google them and select the one that fits your need.When that site comes up you should have all the data you requested.
GS100 trips rear circuit breaker. Found 2 bad output transistors. Replaced all output Q's. Output now distorted. What do i check next?
The big question is what caused the output transistors to fail...
Most modern audio amplifier circuits are dc coupled for good performance on the cheap and that means amplification stages can't be considered independently and several stages must be considered as a whole.
Some circuits are more sensitive than others and more highly stressed. If it has a complementary pair output stage the transistors should be a matched pair.
The reason for this in a dc coupled circuit the bias and the quiescent current for each stage is controlled by earlier stages - when an output transistor pops, the fault is likely to be several driver stages back.
When a transistor is replaced the gain is likely to be different to the original and so the bias and quiescent current must be checked and adjusted in order for the finished job to have long life and good performance and this usually means some component values have to be changed slightly...
Output transistors
a transistor has 3 leads,[emitter current, collector current, base current, i am going to give you list of options that the transistors can be used for and it depends on the configuration of the circuits.
input resistance, current gain, voltage gain, output resistance, power gain, voltage gain, (input and output power) + [input and output voltage] and {input and output resistance} + input and output power gain.
18 various formulas to a range in groups of 2's
2answers
Marantz audio amp. How to set quiescent current on output transistors
Hi, quiescent current is set with a diode string located far away from the output transistor high miller compensation cap values used, quasi-complementary (of course), lots of non-linear, single-transistor gain stages here and there.
That's all i can remember about it...
Take care
2helpful
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
2helpful
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
1helpful
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
I have an audiobahn A8000t amp with the protection light on
Note:
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
1helpful
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
