Panasonic KX TC1881B Cordless Phone (KX-TC1881B) Logo
C
Claud Paradis Posted on Nov 03, 2013
Change time How to change time on the base unit
BionicBilly
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Nov 03, 2013
BionicBilly
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
3183
Points
52
Press "OK" button.
Scroll down to "Settings", (May be handset settings.)
Go Right on scroll button.
Scroll to "Date & Time settings"
Enter date and time.
Unit 86722 will not stay on Central Std Time keeps switching to EST
https://manualsbrain.com/en/manuals/776563/download/
DST SETTING (daylight saving time) 1. The ON digit will start flashing on LCD1. Set the DST ON or OFF by pressing the + key. 2. Press the SET key to enter the "Language Setting". Note: The DST default is "ON", meaning that the WWVB will automatically change the time according to Daylight Saving Time in the spring and fall. For areas that do not recognize DST changes (Arizona and parts of Indiana) turn the DST "OFF".
If DST does not remain ON, rry replacing batteries in base with new 1.5V AA alkaline, regardless of the base battery indicator status. Do not use rechargeable batteries in either base or remote.
Use non-rechargeable lithium AA batteries in remote sending unit if outdoor extreme cold.
How do I change the handset NUMBER on my Panasonic cordless phone model KX-TGA652
Found out how to change the handset number [1] [2] [3] [4] etc on a Panasonic Cordless handset
Panasonic KXTG6644B
Changing Handset Number:
Deregister two Handsets [#1 & #2] 0r [#3 & #4] etc
On each handset hit -
[MENU] # 1 3 1
[ERASE] [YES]
(This leaves and open space on the base unit)
Re-Register 1st Handset [#1]
[MENU] # 1 3 0
Hold [LOCATION] on Base Unit 5 Seconds
Place the Handset you want #1 in Base Unit
Re-Register 2nd Handset [#2]
[MENU] # 1 3 0
Place the Handset you want #2 in Base Unit
1helpful
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Remote sensor (thn122) not working, batteries changed, terminals cleaned
I need to reprogram my 5655 so that the correct date and time is announced by the system
The time and date is set at the base unit.
Press the TIME/SET button
Press the TIME/SET button again
Press the CHANGE button until the correct day is announced
Press the CHANGE button until the correct hour is announced
Press the CHANGE button until the correct minute is announced
Press the CHANGE button until the correct year is announced
Press the TIME/SET button to finish and the current clock setting will be announced
You can hold the CHANGE button down when setting the minutes or year to increment in steps of 10. Following is a link where you can download the manual.
http://att.vtp-media.com/ecp/documents/product_Product/614/UserManual/2041/e5655_manual_bkm.pdf
1helpful
Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Change the frequency
hello firstable you need to know at how many ohms is the base unit then in microphone change the impedance transformer to match the low or high frecuency you want......saludos
5helpful
I get CL blinking on the base
A flashing “CL” in the message window indicates that you must set the correct
day and time at the base unit.
1. Press the TIME button. The system announces the time and day of the week,
followed by "To set day and time, press TIME/SET."
2. Press the TIME button. The system announces the day.
3. Press the CHANGE button repeatedly until the system announces the correct day.
4. Press the TIME button to save the new setting. The system announces the setting.
5. Press the CHANGE button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6. Press the TIME button to save the new setting. The system announces the minute.
7. Press CHANGE to advance the minutes one at a time. –OR– Press and hold the
CHANGE button to advance the minutes in increments of 10.
8. Press the TIME button to save the new setting. The system announces the year.
9. Press CHANGE to advance the year one at a time. –OR– Press and hold CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME. The system announces the clock setting.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
