SOURCE: PIXMA 830 Smudges when printing envelopes
On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
Another idea is to adjust the "ink drying wait time" to a higher level.
SOURCE: Cannot print envelope on MX310
Note:
Note:
Printer Driver Settings:
1Select Envelope in Media Type.
* In Windows, select DL Env. or Comm. Env. #10 in Page Size.
SOURCE: Canon IP4600 won't feed from rear tray.
It turns out that if you read the documentation VERY carefully it says that "if the application program specifies 8.5x11 plain paper and that is what is loaded in the front cassette you cannot print from the rear tray". It turns out that this is true even if you go to the printer driver and specify "rear tray" manually. The driver disregards the setting. You can force printing plain paper from the rear tray by going to the Canon "My Printer" icon and forcing ALL printing from the rear tray. If you do this, remember to change it back. You can also print plain paper from the rear tray if you specify the "allocation" option and the paper from the front cassette runs out. You can always print from the rear tray if the application that created the print job specifies something other than 8.5x11 without resorting to the forced override, e.g. printing a .jpg or .gif or something from an application like Paintshop or Printshop, etc.
SOURCE: my printer keeps printing from rear tray when i
Most of those have a button marked feed switch and a picture with a LED that either shows rear or bottom tray. You need to select the right tray on the printer panel.
SOURCE: I have a Canon Pixma
When you double click the Printer and Faxes icon in the Control Panel
you will see the printer that your computer is currently using. See....
if the printer image is clear it is online and ready to use, if its
blurred then its in offline mode and cannot be use.
To correct
offline printer.. some possible reasons is on the usb cable.. check if
there is no open wire along the cable...Inserting the USB connector on
the other usb slot of the cpu sometimes work just wait first until it
is read.
If the printer is still blurred and offline after
checking the usb connection, the 2nd thing to do is check the
properties of the printer if it is set to offline mode. how? Double
click your printer icon. It will display the print jobs window. Click
on the Printer tab and uncheck on the "Use printer Offline". Cancel all
pending print jobs, close the printer window and try again to print.
