SOURCE: Bosch PowerStar125 won't heat and I can't get one element to work
It sounds like you have a copper canister unit. Ohm out the elements in that one canister. the directions are on the websight for bosch, or I can walk you through it. But you will need a digital multimeter to do this. If you have a blown element in that one canister, then the tco will not reset.
SOURCE: BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
Q.
FA - Gas leakage error, gas valve circuit not closing properly
A.
Q.
EA - No flame ionization detected with water flow
A.
Q.
C1 - Fan rotation too low on startup
A.
SOURCE: 125FX (with FXhood) turns off while in use
may be overheat stat or fan check little hose at fan area for pinhole best of luck
SOURCE: heater is ae125 is about
Hey did you ever get this fixed mine is almost the exact same thing we've been using ours for about 3 years and today nothing. Thanks for your help.
SOURCE: Bosch Pro Tankless - Shows error code E4 - every
E4 error code on Bosch tank less hot water heater, this is what it says.....
E4: Backflow temperature sensor over 309°F. The appliance will close the burner and lock.
A.
Check combustion air and backflow vent piping for blockage.
Check if secondary fan connections are disconnected.
Check
venting specifications are met. Long vent lengths, venting with more
than three elbows, blocked vent or combination venting may cause this
failure.
Check sensor resistance (see Fig. 61, page 44 in manual).
