Question about Compatible Develop Ineo 300, Ineo 300, Ineo 351, Ineo 351, Ineo 352, Ineo 352 Color Black Laser Toner Cartridge / Copier
I can't share my printer ineo+351 i don't have the
I can't share my printer ineo+351 i don't have the driver, and i can't access the IP
    New Friend:
  • 3 Answers
You must press Utylity/Counter next open on screen admin setting. (Pass is 12345678) next network setting, IP setting and you can set IP address. If network (card, cable, switch or router) are OK you can print on your Develop. Driver you find on www.develop.de or http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
Posted on Nov 03, 2013
6ya staff
SOURCE:
Machine status 8/ / / /
http://farbtoner.com/develop-ineo-c-200.html?language=en
Aug 14, 2014 | Compatible Develop Ineo 250, Ineo 250,...
Develop ineo 161 drivers for windows 7 printer Download
need software driver for Ineo Develop 161 photocopier
for windows 7 & 8
Mar 09, 2013 | Toshiba e-Studio 161 Copier Copier
Hi, I have brought my dell laptop at work with vista operating system. It connects to internet networks wirelessly. I am trying to connect the work printer to my laptop but am not sure how to start. The...
hi,
you do not need a CD to connect to the printer, what you should do is gain access to the print server. this can be done by asking your network administrator. in a situation where you don't have one or the network is an open one, you have to connect to the printer network, open your ipv4 properties and select obtain an ip address automatically, do the same with the DNS server and you're good to go.
just so i'm thorough, after connecting to the print server / network, you can access your network ipv4 properties by right-clicking on the network icon located at the lower right corner of your taskbar, (the bar at the bottom of your screen) usually in form of two computer monitors. select network and sharing center after right-clicking. a list of wireless network should be available if there are more than one wireless networks in the area. select view status of the print server / network, click on properties, a pop-up box appears. be sure 'file and printer sharing for microsoft network' is checked, double-click "internet protocol v4 (ip/tcpv4)' select obtain an ip address automatically, select the same for the dns server below. click OK you're good to go.
note
once you are successfully connected to the print server, click on Devices and Printers from the start menu, select the printer and allow the drivers to be installed from the server. once that is done, you can right-click on the printer and select set as default. after this all you have to do is connect and print whenever you want to.
hope this helps
let me know if there's anything you don't understand or if this doesn't resolve it.
Jul 18, 2011 | HP LaserJet P4015 Printer
NEED INEO 163V DRIVER
i want driver ineo 163n printer
Jul 01, 2011 | Office Equipment & Supplies
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
Please help me to configure network scanner in develop ineo 250 model.If I check in Our Printer summery its showing optional printer is not configured but I give destination IP and folder path every...
alright follow these steps to properly configure the scanner on a network. first of all you need to make sure you have the proper drivers for the scanner. second, you need an IP, Subnet mask, and gateway that are all STATIC, not DHCP. you need to make sure that the folder you are trying to scan to is shared out correctly, and the scanner has full access rights to the folder, meaning a user name and password. if the folder is not shared out you will not be able to push a scanned image. any other questionns just let me know.
Jun 20, 2009 | Office Equipment & Supplies
Can't connect 2 pc to 1 printer
Steps to fix your issue
  1. install printer driver on one computer
  2. Make sure both computers are connected in same network by ethernet cable or wireless connection.
  3. share the printer on 1st computer
  4. access the shared printer from 2nd computer through network
This way your can access one printer from 2 computers. This setup work only when the 1st computer is turned on because HP leaser jet don't have the capability to work as network printer as they cannot acquire IP address.
If u need further information on how to configure 2 computer please refer below link
http://www.ajcsoft.com/connect_computers_together.php
For information regarding how to share printer on windows XP refer below link
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Dec 30, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Access denied to network to laptop
Disable all firewalls, both on laptop and on computer that shares the printer.
Ensure that laptop and desktop sharing the printer are both on same Domain or Workgroup.
If this does not fix it, call back the Geeks and thell them to acces the router configuration, and configure router internal firewall.
Put both laptop IP and computer sharing printer IP in the range of thrusted IP on router settings.
Sep 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Compatible Develop Ineo 300, Ineo 300, Ineo 351, Ineo 351, Ineo 352, Ineo 352 Color Black Laser Toner Cartridge / Copier Logo
157 people viewed this question
Top Compatible Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Compatible Office Equipment and Supply Expert? Answer questions, earn points and help others
