SC401: Transfer roller leak error 1 SC402: Transfer roller leak error 2 -Definition- [B] A transfer roller current leak signal is detected. The current feedback signal for the transfer roller is not detected. - Possible causes - · High voltage supply board defective · Poor connection of the PCU · Transfer/separation unit set incorrectly
No, it will not show up there. It can scan two different ways. One is the scan router program installed on your computer. The other is scan to folder via SMB. It merely is a path back to a folder.
If you go into: user tools, system settings, administrator tools, and address book management. The settings will be in there.
You could also "web" into your machine using IE and the IP address. Login as "admin" leave password blank. Go to the address book. Email me if you need further info.
You can install the Twain scanning driver which is provided on the Printer driver CD. Insert this CD and select to install the Twain driver only.
After installation od this driver, please open Word document and click on Insert, Picture and select from Scanner or Camera. Check and choose your twain scanner driver and click on insert.
Beforehand you must put the original on the exposure glass.
Try this or you can use scan to email but you need more setup details.
Hope you good luck.
