SOURCE: Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
SOURCE: Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
SOURCE: error code on electrolux
Haven't tried your solution but I'm keeping it in mind. I talked to a repairman and he suggested I remove the panel at the bottom of the dishwasher (left side). There I will see a red button which is the control board processor reset button.
This worked but if the problem reoccurs I will try your solution as it is easier than removing a panel.
SOURCE: Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
SOURCE: My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
We had the same light show up last night, I can't find anything anywhere that explains what this particular combination of lights means - any help much appreciated.
