Make this test and fix it. God bless you
Testimonial: "None of this has anything to do with the problem."
SOURCE: Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
SOURCE: MY MICROWAVE WILL NOT DO ANYTHING
I couldn't find those exact trouble codes, but a common problem is when the controller gets damp, either from steam rising from the cooktop or someone spraying cleaner directly on the keypad. Cleaners should always be sprayed on a soft cloth, then wipe the keypad with the cloth. Also, GE / Samsung codes of F1, F2 and F3 may be the same since Samsung makes GE microwaves. Those would mean trouble with the temperature sensor, keypad, or control panel. Assuming your control panel is clean and dry, it may be time to call for service.
SOURCE: My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave Model 40180089700 shows "5E"
You have an error code and probably for good reason. maybe a switch is bad to keep out radiation for closing the door or what ever . If you don't know about these things don't mess with them! They are very dangerous and it can radiate you with out you knowing in some instances. Not worth messing with ,too dangerous for the unknown guy!!!!!
SOURCE: Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
