I have a BB 7130e that I've used for the last 4 years. I recently purchased a BB 8330. I am having driver problems. I am unable to connect to computer. I uninstalled DM v.6 and installed v. 7. No luck. I then went back to v. 5 - still no luck. Computer running XP Professional - no windows update shown.
SOURCE: blocking calls for bb curve 8330
go into calls and press the menu botton and you will see call barring select it and you see all the options
SOURCE: how to block certain numbers on my BB 8330
If you activate call barring, you would not receive any call. It always refer to all calls not a specific number.
To be really honest, there are only 2 ways "-
1. Call service provider and block numbers. However, usually they do not block any numbers without any reason.
2. Download blacklisting software for blackberry. Once downloaded, mark that number in your blacklist directory and whenever the person calls from that number, it would always show a busy tone to them.
Google it out for blacklisting software for your model.
Any further help, let me know.
Thanks for using "Fixya".
SOURCE: I have a blackberry curve 8330 and i attempted to
Download and install the latest Handheld Software for your model then open DM and run the application loader once the USB cable is connected to the device. Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=6C3CF77D52820CD0FE646D38BC2145CA&dl=1AFC1734DBC097C238596D7956CDA0A8
Just fill out the form and the download is free.
SOURCE: cannot pair sbh500 bt headphones with my BB curve
my guess will be that there is a button on sbh500 (probably the on button)
that while you are pressing on it the device can be detected.
SOURCE: BlackBerry® Curve™ 8330 Cellular Phone: hello! my bb curve 8330 won't power on, it is givi...
Might be that the battery is dead.
let it charge for hours without trying to power it.
after that, unplug and press the start button and let it works a few minute. it might take a while.
good luck
