SOURCE: LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
SOURCE: banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
SOURCE: I have am lg wm-1832c front loader. Rinse cycle fill problem
the pc board is bad must replace.
SOURCE: I have a leak in
That should not be too hard to find Click here=>Your part number is 5221ER1003A You can find your part here=> 5221ER1003A Water Control Valve
If you need additional help feel free to ask me, Thanks Sea Breeze
SOURCE: I have a fuzzy logic 8.2kg top loader WF-8071TTP.
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
