How to replace the small belt? I can't find a way to reach it
This is what i rendered to another person asking about replacing belts in a tape transport
Can you not retrieve you tape ?
this is caused by a safety feature, your tape is not damaged more than it might already be, if your take up spool the right side dos not rotate when it is suppose to it registers a fault. in all cases it simply dos not play the tape.
some other units require the loading of the tape path components IE pinch roller/ and tape pickup heads if this function is interrupted and unable to complete its cycle you will not get your tape back until you disassemble and manually advance the function to it`s conclusion ARE YOU PREPARED TO UNDERTAKE THIS PROCEDURE ?.
