Open leverCheck your
microwave lever to determine if it is damaged. If it is broken, simply
replace the lever to get your microwave door fully functional again.
Door springResponsible
for keeping downward pressure on the door hook, the microwave door
spring can begin to malfunction. If this part is broken and prevents you
from opening your microwave door, replacement is necessary.
Door latchOne reason
your microwave door may not open properly is a broken door latch.
Located inside the microwave, the door latch manipulates the door hook
to keep the door closed for safety and top performance. If broken, the
door could become stuck in the locked position.
Door hookIf your
microwave door will not release properly, the door hook could be
damaged. Located inside the door, the door hook is made of plastic and
prone to breakage with extended use or age. As this part is unable to be
repaired, the only option is to replace it.
Button or button springIf
the microwave door will not open, it could be an internal failure of
the button or button spring. If it is determined that either of these
parts is the source, both are replaceable and it is recommended that
they be installed at the same time.
Handle actuatorIf the
microwave door will not open the plastic handle actuator could be
broken. Connected between the door button and the door latch assembly,
this plastic part could become damaged and brittle over time, which
makes breaking inevitable. If this occurs, replace the handle actuator
to get your microwave fully functional again.
First I'm not a Kitchen Aid tech.
* The fan is stuck on or the cook cycle has not completed. Either way something is wrong. Try unplug the Micro wave and let it rest for 10 seconds. Power back up and see if the fan still runs. If so then pull the plug. Don't use the M/W
* Check your warranty and call or take it to the service center.
* There are no customer serviced parts in a Micro wave.
*** High Voltage present. High Gauss Magnets present, High voltage storage device hazard present even with power off and disconnected! ***
* Be safe, call for service or get a new unit and dump this one.
Aloha, ukeboy57
KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
When the fuse blows in the microwave oven, it is often caused by a bad door switch. Sometimes food build up will clog it, or becomes defective, the only way to fix it is have it replaced.
the micro switch is probably faulty which tells the machine the door is actually closed or open. this would need replacing which means pulling the unit apart.
hope this helps
