Remove the battery. Wait a minute. Put the battery in and plug in the charger and connect it to the camera. If the power button glows and a green LED flashes it is taking a charge. Do not try to turn the camera on UNTIL you can get it to charge.
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back. Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it. If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
The flash on D series doesn't always open by itself or when you push the button, as part of the design. If you are in manual mode the flash should open when you push the button, but when in Auto, if there is enough light present for the flash to stay closed, even if you push the flash button, I don't think it will open.
In Auto mode, try pointing the camera at something dark or holding your hand up in front of it and push the shutter button halfway down to see if the flash opens. If not, you will probably have to take it in to be repaired.
have you already pushed the focus point button - top right, under your thumb and then push the set button? Pushing the set button will flip between only the centre focus point and all 7.
