I have just changed the flapper and it still intermittently keeps running.
I also took apart the valve and cleaned it. Stopped running briefly now problem has resumed?
Should I replace the complete valve or just the Replacement cap?
Any other suggestions?
I also have TOTO. Put food coloring in tank and it does NOT show in the toilet bowl. I can see water running down the inside of the bowl but it is NOT the color of the food coloring. It is clear. Now what?
Water fills to the overflow and keeps running. To stop it, I have to remove the cover and push down the float. This will stop the running water until the next flush.
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
