SOURCE: i need to import video from my canon zr500 to my pc
Hi!
You can import videos from your camcorder to your PC using a DV cable. Check this page from the user guide of your camcorder.
Basically, you need a firewire port and a DV cable. Most computers (new ones) already have firewire ports (or 1394 ports).
I hope that helps.
Good luck and have a nice day!
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
SOURCE: No DV output from Canon GL2. Using a firewire
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
SOURCE: canon hv 40 cannot import video to the computer
have tried everything - every combination of settings - my hv 40 and windows 7 and 4 diffrent programs can not capture hd video - will capture dv - can control camera from computer in hd mode but no program will switch to hd capture mode so if you find an answer please let me know
SOURCE: I can't upload video from my Canon GL1
first off make sure you are positively connected to computer via usb. then make sure your drivers are updated. then see if it connects. also note that your camera screen may say "would you like to connect to usb port?" make sure if that does appear that you hit yes. best of luck!
