Asrock K7S41GX Motherboard Logo
?? ? Posted on Nov 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What the max memory it supports? - Asrock K7S41GX Motherboard
mikadot
Level 3:
  • Master 2,113 Answers
  • Posted on Nov 01, 2013
mikadot
Master
Level 3:
Answers
2113
Questions
0
Helped
465916
Points
5959
Says 2 gig on NewEgg
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
2answers
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • 0helpful
    3answers
    Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
    You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
    Maximum Memory: 2GB
    Slots: 2
    Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
    Hope this helps.
    1helpful
    Can i put ram from packard bell easynote into an acer aspire 5315.thanks
    RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
    2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
    2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
    2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
    2helpful
    Can I upgrade to more than 2gb of memory
    I am sorry to say that the max is 2GB.
  • Memory Support:
    • 2 x 184pin DDR Memory Slots
    • Supports DDR 400/333/266 Memory Speeds
    Max Memory Capacity 2GB
  • Read more: http://www.outletpc.com/c3920.html#ixzz17RcYkWNS Thank you, Chris Anchor Installations
    4answers
    I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
    Hi this model sopport 2Gig Memory Ram.
    RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
    Please check in to your Bios system maybe share memory Video or capacity is setting
    I have a ms 7312 what is the max memory I can install on it
    Hello, I've pasted the below from the MSI website for the board:
    bult_ar_org.gifMain Memory
    • Supports Dual DDR2 533/667/800
    - 2 DDR2 DIMMs (240pin / 1.8V)
    - Supports a maximum memory size up to 2GB.
    regards,
    Nicam49
    p.s. don't forget XP supports 2gb max anyway.
    2helpful
    2answers
    I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
    Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
    Hope this is what you are looking for,
    Cheers,
    Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
    Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
    From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
    Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
    4 GB max 4x1024 184pin
    Hope this helps.
    Top Asrock Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
