Most of the igniters are located in the lower front area of the dryer. You need to remove the top cover from the front area , using a spatula to Pop it open (don't forget to remove the filter if its located on the top, Including the two screws that hold the base) . Then you need to remove the front plate by removing two screws from the inside upper Area . The igniter is a ceramic fuse that will click and glow completely Red and ready for the gas to create the flame and heat for you dryer. If you model has a bottom front cover only and after you remove it ,then it will be easier to observe The actual process of the igniter if it is working properly . Good luck
Ignition Switch Will Not Turn Off?
http://schematicsdiagram.blogspot.in/2012/04/ignition-switch-will-not-turn-off.html
1995 Ford Taurus: Ignition switch not turning OFF?
http://repairhelpcenter.blogspot.in/2012/06/1995-ford-taurus-ignition-switch-not.html
Ignition Problem Troubleshooting
http://whoisbyme.blogspot.in/2012/07/ignition-problem-troubleshooting.html
These
will help.
Thanks.
IGNITION SWITCH REPLACING
It
depends on vehicle to vehicle. But it's not very difficult on mot of cars to
replace ignition switch. Basic theory of replacing ignition switch is same for
all car models. -----
To
replace ignition switch on your vehicle, I suggest you
few helplinks with proper ignition switch replacing procedure.
View its details and you can replace ignition switch on your
vehicle.
Click
the link below: ------
How to remove ignition switch on VW Car models?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-ignition-switch-on-vw-car.html
How to replace Ignition Lock Cylinder on Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-lock-cylinder.html
http://repairhelpcenter.blogspot.in/2012/06/ford-taurus-ignition-switch-steering.html
How to replace Ignition Switch on
Acura Car Models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-ignition-switch-on-acura.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-ignition-switch-on.html
These will help.
Thanks.
Ford Taurus: Ignition Switch & Steering Column Replacing?
How to replace Ignition Switch on Acura Car Models?
How to Replace Ignition Switch on Chevrolet
Caprice Classic?
These will help.
Thanks.
