Check all your grounds for corrosion, wire damage, and contact points. If it did it before you changed the first seat switch and still does it, then its not that. Check fuses is there are any. There are 3 safety features that all work in conjunction. Blade engage, parking break, seat switch. Varying by type of mower.
SOURCE: mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
SOURCE: release brake engine dies engage blades engine dies
there is a saftey switch on the deck that has shorted out need to replace
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
SOURCE: riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
