You need to find out what is lagging. Try http://msdn.microsoft.com/en-us/library/hh162945.aspx
this will show you the culprit!
SOURCE: "Windows vista booting corrupt"
try to boot ur laptop with disc manager cd or win XP.
if doesnt works then try win 98 cd and delete ur C:/ partiton and install new vista
SOURCE: specs say the Lenovo G560 067999U has max memory
According to the manufacturer's system specifications, the Lenovo G560 067999U uses Integrated Intel Graphics HM55 shared memory. This means that the graphics card would use a portion of your 8 GB RAM for video memory use. Check the system BIOS settings to see how much RAM is allocated to your video.
SOURCE: my laptop takes a longer
intall a antivirus kesperkey 30 trial pack , update it scan and try
SOURCE: want to change compability to AHCI mode in lenovo z570 ideapad
This is a setting in you BIOS. Try changing to AUTO under the SATA drive settings by pressing F key during boot. It will be noted on screen during startup.
I would stay away from a OS upgrade till your are certain all hardware and software is compatible. It is a lot of work if it does not work properly.
SOURCE: PRINTER TO LAPTOP
First download and install the correct software for the Printer on the laptop, you didn't post the HP printer model. In the install of the software follow the on-screen instructions. OR plug in the Printer using a USB printer cable, the Win 8 software should try to apply the driver, if available, but you may not have ALL the printer functions until you install the correct HP Printer software.
