Panasonic Palmcorder PV-GS12 Mini DV Digital Camcorder Logo
a
ajazpasha Posted on Oct 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mute handycam dcr
Audio drops while playing
Al Rush
Level 2:
Sergeant:
Champion:
  • Expert 270 Answers
  • Posted on Nov 03, 2013
Al Rush
Expert
Level 2:
Sergeant:
Champion:
Answers
270
Questions
0
Helped
51164
Points
517
Could be because LP record mode was used.
Alo it may be tape dropouts.
Dropouts occur after too many record/erase cycles.
Al
My Handycam shows a bluish screen(DCR-HC32E)
did you happen to drop the cam? there could be a technical error with the LCD screen. take it to the nearest Sony service center and have them take a look at it. you can try resetting the cam and see if it changes anything.
Handycam DCR-TRV22 Records Audion no Video
Need go buy a cleaning tape from any local retailer and play for one minute. Video should comes back up.
1helpful
Sony dcr-trv25 when playing back tapes sound goes on and off pic sometimes distorted tried cleanig with tape still doing same thing I dropped camera from a standing position (3ft) nothing broke thats when...
Yes sounds as though the audio playback head had become misaligned by the drop... You will have to get it back in position again. Thats a job and a half though, really only something that can be done by a tech?
2answers
Does not record video but records audio. will
Pushed the reset button under the flip out screen and viola it worked AOK.
Sony dcr-trv320 won't record audio
Go in menu, go to sound and make sure it is turned up.
Sony dcr-dvd105 no sound
Try this:
Play back a recently recorded scene through the viewing screen. Make sure any "mute" setting is turned off and turn the volume up. If you can hear the sound, the problem is not in the camera. Also, run through your menu's audio settings to make sure that they are set correctly.
If you can't hear any sound, repeat the process with an external mike attached. If this gives you sound, the camera's built in mike is defective. Time to hand it in for repair.
If you still can't hear any sound, something else is wrong with the camera. Again, send it in for repair.
1helpful
Sony Handycam issue - repair/replace?
Your camera has bad CCD Imager and needs to be replaced this part. Good news is Sony will repair your DCR-TRV19E free of cost. Please check Sony Website for details.
Regards,
1helpful
Sony Handycam DCR DVD108
The only way to cut off the sound on a handycam is to connect up a blank micro jack plug to the microphone input. Unfortunately the DVD108 doesn't have this option.
Help me
first, verify your taped video is ok by doing this: connect your audio out RCA jacks to a cable to the input of a stereo. now play it. if audio ok, then problem somewhere from audio amp section to speaker on SONY.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
