The air conditioner is not working and the thermostat says it's in recovery mode
By the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Cant tell why your ac isnt workin but recovery mode means its coming on to obtain set temperture
The outdoor unit has a fan relay in it. Your stat talks to the outdoor unit. If the fan relay is bad than the indoor evaporator fan will not operate. If the outdoor unit isn't running it's probably the low pressure and/or high pressure switch has cut off inside the unit. It needs to be manually reset. Its also possible that you have a bad switch too.
