Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
My hp2110 printer shows yellow stripes when printing photos. Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints ok, but copying photos in library printer prints yellow horizontal stripes.
    Scholar:
  • 123 Answers
Go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Posted on Apr 29, 2009
6ya staff
SOURCE:
Fix a xerox 6350DT
If you have a white stripe in only one color, then you might have a bad developer. Each color has its own developer
116-2008-00 Yellow
116-2009-00 Magenta
116-2010-00 Cyan
116-2011-00 Black
Changing the developer is not super easy. You'd have to remove the left cover, HV Power Supply board, then remove Image Unit and the Developer Frame, where all the Developers are mounted. Detach the feed hose for the Developer you want to change and release the Developer's 2 spring clips.
The attached photo shows old developers which have dead spots that would cause the missing stripes on prints.
Sep 12, 2014 | Xerox Phaser Office Equipment & Supplies
HP Printer C6100 All-in-One series Power went out a few times in one day - then printer was stuck on photo print only - uninstalled and reinstalled the software and followed all the...
Okay..... George and Louise
The problems is..... the printer is stuck on a print error....
Now have a "HP Printer C6100 All-in-One series"!!
so you would need to download "HP print diagnostics utility" for type of windows you have on your computer ......
the print diagnostics utility should fix the print error right away....(To do this... you must install the driver and any software for the printer... to make sure that there isn't any communication problem between the printer and the pc... )
Apr 04, 2011 | Office Equipment & Supplies
My hp all in one 6500 keps saying that i cant print because its not connected to a computor but it is?
If you're getting an error about the connection you have to make sure that the USB cable (if connected by USB) is plugged in correctly, or you may try reseating it.Unplug the USB cable. Reconnect the USB cable to the back of the printer and plug the other end to a USB slot in the computer. Make sure that you hear a sound in the pc when you connect the USB, that means that your pc has detected something. Also try downloading a Print Diagnostic Utility from HP website, this tool is pretty useful printing probems.HP website, then click on Support and Drivers, then go to Download software and drivers, key in the product name and hit enter. Choose your OS and hit next, click on Utility and Diagnostic Tools and click on HP Print Diagnostic Utility.
If connected wirelessly, you can also try the HP Print Diagnostic Utility. If you get an error on connectivity, make sure that the printer and the computer are on the same IP address. If both have the same IP address and your pc still can't detect the printer try updating the software by downloading it from HP website.
Apr 04, 2011 | HP Officejet 6500 Wireless All-in-One...
I am getting an error message, "A printer has occurred. Turn off the printer, them press On button to turn on. See your documentation." I have done this a number of times on a number of days....
Hi
Just download, unzip and uninstall the PRINT DIAGNOSTIC UTILITY (click on blue name) http://www.out-of-warranty.com/print-diagnostic-utility-for-hp-lexmark-canon-dell-xerox-and-everything-else/. Once installed, just click on the PRINT DIAGNOSTIC ICON to fix errors in just a second. Then try to printer again after restarting your computer and your printer.
I will helps you solve your problem.
Regards
Feb 20, 2011 | Epson Stylus CX9400 Photo Printer
My photo prints have horizontal stripes.
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printing pictures
Download the Print Diagnostic Utility from this HP site (click on "click here to download the Print Diagnostic Utility" on this HP document, then install it and follow the directions on the page.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01072463&dlc=en&product=3194498
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 23, 2008 | HP Photosmart C6280 Printer
724 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
