Sony Wega Plasma 42XS955. Over 2 wks., gradually took 10 min. for Pix to come up, then went to 1/2hr., then 1 hour, 2 hours (all with sound). Now no pix and no sound. Is the TV kaput, or fixable?? Blinking green 10 times and now red. Mfg 9/04, Japan.
I would check the capicitors on the power supply to see if the they are bulging at the top or leaking. I had a Samsung lcd that starting taking and hour to turn on then eventually it would not turn on. So I checked the power supply and saw four bulging capacitors that I replaced and now it's working like new.
SOURCE: TV green lite comes on for 2 seconds--goes back to
you posted the model number in reverse-----32pf double check-only thing i found so far -------replace c601 470/25v
someone else found a bad FET did u check them
do u have a pdf of this one
SOURCE: I have a 42
There are a number reasons why this might happen:
Thanks
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
SOURCE: hello our sony grand wega KDF e55a20 has the green
Symptom shows Lamp is not working and either lamp or its drive board is bad that will be replaced.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual.
Thanks.
