Hi, how do you calculate IRR (Internal Rate of Return) on the Sharp EL-531W scientific calculator? E.g. for calculating uneven cash flows. I found a tutorial online for the EL-733A but the buttons are different on the EL-531W.
Please help.
D
SOURCE: Computing IRR calculator goes blank and outs Error 7
I belive this will fix the problem i was sitting here having the same deal waiting and waiting..then bam error 7 then i fixed it so thought i would put what i did.
go into your CF and delete all the unused CO times..for instance if your using 3 periods...delete all CF05 and F05 the last one should be C04=0 and F04=0 make sure your NPV is the same after messing around..then try to compute IRR popped up in 2 seconds for me.
word hope this helps u all ***420*** :0
SOURCE: SHARP EL-531W HOW DO YOU CALCULATE MEAN,STANDARD
for the mean, just add them together and divide answer by the amount of figures you put in. as for the others, i'm not sure a standard scientific calculator will do that
SOURCE: how do I use sharp EL 531W to solve quadratic equations?
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Callit disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
SOURCE: sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
SOURCE: Dow to get complex mode in EL-531W
This calculator has no Complex calculations feature. You cannot therefore enable it.The only solution is to get a calculator that has this function.
