SOURCE: "searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
SOURCE: Problem with ATT cordless phone set (3 phones)
I wonder if any one who asked this question got an answer to this good question. I am having the same problem. I need some help.
Gene
SOURCE: our system E5947B has 4 phones - three of which
try removing the batteries from all of the hand sets.wait 30-60 seconds. 1 by 1 replace the batteries and place them on the main base. this will re-register the phones 1,2,3 etc. as you plug them into the base, they will be numbered sequentially
SOURCE: the cordless handset for my
For now simply try unlugging everything from the outlets for about minutes.If that does not work,I will locate the info tomorrow about some other possibilities.Different makers have different ways to access the program part and I will look for what may cause it.Good luck,Greg
SOURCE: AT&T EP5632 phone won't register or find base.
I had the same problem happen to me as well and I took the batteries out of all handsets, and unplugged the base for a few minutes. Then plugged in the base, reinstalled the batteries and it registered all handsets lickety-split. Hope this helps you.
