SOURCE: Samsung Plasma Display HPN5039
Vladislav was able to fix his TV by replacing some defective capacitors in the power supply.
The locations of the defective capacitors are C523 and C524. The value is 0.22uF 400VDC or can use 600VDC as well.
You can also buy the entire power supply assembly by clicking here.
Good Luck.
SOURCE: I have a Samsung plasma hpn5039, and i was
Two things,
1st -- power board problem
2nd -- Y- Main Board problem
If you are familiar with TV,
Open the back panel first then check the fuse on power & Y-main
Board.
It had problem that the board's which disconnected fuse on.
SOURCE: Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
