Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
Posted on Apr 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
I have a whirlpool dishwasher (gu2500xtpq6) that when started fills some then runs for about 30 seconds starts filling again then runs rest of cycle, but with the 2 times filling still doesn't fill up all the way just a little water can be seen in bottom.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
547
Points
Whirlpool gold starts the soaking time but dosnt run after that the time remaing light just blinks
Ron Coons
Level 3:
President:
  • Whirlpool Master 2,651 Answers
  • Posted on Apr 29, 2009
Ron Coons
Whirlpool Master
Level 3:
President:
Answers
2651
Questions
Helped
1546933
Points
7824
Water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Whirlpool Dishwasher will fill water then stops
If it fills with water properly then stops, and especially if there is a humming noise, it is possible that
- motor start capacitor has failed
- drive belt has slipped or snapped
- belt tensioner spring has broken
2helpful
Will not fill up with water before starting, it takes about 3-4 times brfore unit will run with full amount of water. loads take forever.
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
Whirlpool DU943 leaks heavily when filling from
I doubt the H2O tank temp would have any affect... to fix the problem you will need to pull the unit out and replace the supply line from the valve to the elbow... I would recommend braided line.
If your talking about the fill tube that loops up the side of the unit it usually is just seperated at one of the fittings and can be pushed back intp lace or recalmped... otherwise you will have to purchase a new oem tube.
Dishwasher wont fill
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Whirlpool dishwasher.
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Whirpool diswasher DU929PFGG2 wont draw water
The pump may be clogged or the motor start capacitor may be bad or the fill switch may be stuck or the timer may be bad. Fill the dishwasher by hand to just below the door level and close it then see if it will run. If it then runs correctly the problem may be the fill switch. If not, it could be the motor, the cap, or the timer
Whirlpool Dishwasher Fills and then Stops
  Check your connection where you connected dishwasher to power cord.
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
