SOURCE: maytag dryer model mdg9606aww ,
There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
if this helps please vote me a fix ya
SOURCE: Maytag gas dryer not heating up.
check the gas or have the gas company check it ... also check the igniter. if it does not glow bright it will not open the valve...
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
SOURCE: Maytag Neptune Dryer taking hours to dry a load
Hello Friend, Your solution is simple. It sounds like your dryer is working properly, and your actual problem is a blockage somewhere in your 4 inch exhaust tubing. Check it and make sure it is not clogged up with excessive lint. Also if your tubing is clear you need to check your connection where it travels thru the wall etc. It would be a good idea to find the actual location where it exits to the ouside and check for good airflow. Your dryer is equiped with a safety thermistat and if you are not getting the proper exhaust flow the burner will cut off and restart in the manner that your's is doing. I Hope I have helped you, Tim. And please don't forget to give me your rating for my help.
SOURCE: Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
