Friend borrowed it and changed front panel jumpers...Power SW, HDD LED and Power LED.
SOURCE: need schematics for front panel , power sw , pwr led , hdd led et
Try this link to Emachines page. After you put in the make and model and stuff you should be able to view the user manual for your machine. If this isn't what you need you are able to contact support from this page and maybe they can direct you to a more detailed explanation that may help more.
eMachines use specially-made
boards for them so there is no manual as such as the boards aren't made
to be distributed. Basically they would all use the same sort of
connectors and blocks (and cases) to an extent that anybody can plug a
connector into the right place and it will work.
The easy way to
get round this is to find the power button first - try each two pin
connector first, press the button and see if it comes on. If not, move
along on the block until you find the right one. Then it's just a case
of trial-and-error on the other ones to find reset, power LED and HDD
led.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W4065
SOURCE: same problem - green "power" LED on the MB but no activity
This series of machines is known for this issue. You can get a replacement motherboard for your pc from a website at www.barebonekit.com they boards run from $35 to about $65 plus shipping. This is much cheaper than you can get them most other places. We order from them on a regular basis and have had no problems. I hope this helps, if so please rate the solution.
Thanks,
Buddy
SOURCE: I need to know what colored wires go where on my customers PC hdd led/ power sw/ and power led
the only reason to have removed them was to switch the board or put the board in a new case..if you put a new board the new board is what you have to go by, look in the book, or take the number off the motherboard and go to yahoo and type in schematic for xxxxx board.
DO NOT go by emachine model as its worthless, too many models have different hardware.
This is all basic repair 101, how do you have customers? lol
SOURCE: cleaned Emachines. cant find location of fron
http://www.808.dk/pics/k7s5a_fp1.gif
this is not the same pc but maybe it helps you..;-)
IDE is sometimes HD
SOURCE: Looking for the front panel wiring diagram for a
If you look closely at the board there should be labels printed. The power switch plug can plug in either direction, but the LED must be the correct direction for it to work. No damage can be done by plugging the LED in backwards.
