Hi, I have Toshiba Satellite A305 S6905 model. While turning on the laptop, sometimes it gets on sometimes It wont. I see green light on when I press Function key - and I See white LEDs glowing near mouse pad. I will not see the RAM blinking etc., Some people told me its a RAM slot issue and some told it is a Display IC issue. Please help - I see my screen blank though the power is on.
SOURCE: Screen Brightness gone too low on toshiba satellite 1110 laptop
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
SOURCE: HELP ME!! LCD SCREEN WONT TURN ON! TOSHIBA SATELLITE A215-S5837
it sounds like a hardware problem. I would say your high voltage board that drives your lcd has blown probably the caps you buy new on-line and replace it. send to factory service to have fixed. get fixed on warranty if you have it.
please let me if I helped
As far I know FN keys are related with specific motherboard drivers.
Thoshiba recovery cd/dvd during restore/re-install, loads all toshiba drivers and utilities for operating fn keys.
If the operative system loaded in the laptop is no OEM then you will have this problem, and in order to fix it you must:
First install the operative system (clean install)
Second install: chipset drivers. This drivers instructs the operative system how to detect specific hardware. Must be installed in first order.
Third: install drivers (ethernet card, audio, video controller, toshiba utilities, etc). At this point verify all FN keys ( check display settings, stand by/ hybernation, etc).
four: Load all software needed (microsoft office, etc).
I hope this help to solve your problem
Posted by MCampos
SOURCE: frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
SOURCE: Remove Bios Password satellite A305-s6872
If you cannot find the reset pins try to find the CMOS 3V battery, it is usually located under the keyboard, and disconnect it. remove the computer battery and then start the computer. When you boot it should ask you for the time and date. At this point shut down and plug the CMOS battery back in and reinstall the computer battery. This time when it ask for the time and date go ahead and enter it and the rest of the bios should be set to default.
