Brother DCP-8040 Copier Logo
Posted on Apr 28, 2009
Machine error 7a on brother mfc8640d
Was making knocking noise while printing over past few days. This morning, started to print, made loud band and then error message appeared. Restarted machine to no avail. Opened all doors to check for paper jam but no luck.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
623
Points
Same problem with mine! You can replace cheaper than repair!!!!!
2answers
My brother DCP_7040 has been making loud clicking noises for sometime and will not print I get out of paper message. (It's full of paper.
Check there is nothing in the fuser at the back, and that the fuser will turn (CAREFUL it may be hot) Pull the drum and toner unit out, and separate the two components. Check the Developer roller on the front of the toner cartridge turns smoothly and quietly. Any noise is bad. Check the cylinder in the drum unit also turns smoothly. (turn it with the gear, don't put fingers on the cylinder itself). Put it all back together and listen for noise when the machine winds up. a loud ratchety noise usually indicates the gear train is under too much load and is often caused by a strain on the drum rotor.
2answers
HL-L8350CDW series Unable to print 0A. How do I fix this?
"Print Unable 0A" indicates that a hardware malfunction has occurred.
- If the error message is "Print Unable ZC", refer to: "Print Unable ZC"
1. Power the machine off by holding down the power button. Wait a few seconds and then power the machine back on.
-If no error message appears on your machine's display, go to Step 2.
- If the error changed to "Self-Diagnostic" on your machine's display, contact brother for warranty service.
-If "Print Unable 0A" returns, contact brother for warranty service.
2. Leave the machine with power ON for 15 minutes.
- If "Self-Diagnostic" or "Print Unable 0A" returns, contact brother for warranty service..
WARRANTY AND SERVICE OPTIONS.
Brother Authorized Service Center locator
1helpful
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Print unable error 7a
Canon copier IR 2520 show error code of E000002 please help me
2answers
What is error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock.
http://www.fixya.com/support/t5660619-7a_error
Problems printing to Brother MFC 8660DN printer
Pull the paper tray, likley a small black lever to the left of the roller called the edge actuator is dislodged and hanging down. When in position the actuator should easily push up and appear flat next to the roller.
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
For more information and help........
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
2answers
Loud, knocking noises
your fuser is about to go...
happened to me last week
Samsung SCX-4216F - loud banging noise
the doctor blade in the cartridge tobe replaced.
Norman Weimar
Norman Weimar
k24674
