Does it freeze when plugging in any USB device? Exam the USB port and plug/cable for any damage. I have seen the pins get bent and the tab cracked on a Dell USB port before.
i have had a similar problem before. if you touch the usb port w/ finger before yopu put in usb device does it still lock up comp. if not there is a grounding problem with port. you computer will not see it ever. check wireing to port and to riser on mother board. or add on pci card.
sounds like a faulty USB driver - i recommend uninstalling all USB drivers and using drivermax.com to get the correct ones. Your computer may have automatically updated your drivers incorrectly without you knowing.
Your computer may not be able to handle the 2.0 USB cardbus.
Your PC maybe 1.1 USB. If this is the case you might want to add an additional PCI card with 2.0 USB drives. This way you are up to date with the 2.0 cardbus. Resolve this issue and you should be fixed from the PC freezing.
