My LCD TV picture has red and green colour bleed when the picture shows shadows. often this appears in hair colour or shadow from peoples faces which have a red / green appearance or edge. I have tried with HD TV and the problem still exists. The TV was supposed to be the top of the range during spring 2008. I have noticed this on some other LCD TV's but the majority are ok. Is this right? Can it be corrected? Please help? The colour is driving me crazy and I have been on to Sony to get resolved. What can I expect? Red and Green colour bleed on Sony LCD TV. The thing is only 14 months old.help please!!
SOURCE: sony kdf-e50a12u rear projection lcd bravia. red shadows
This *CAN* be fixed. This TV has a problem with running in the 60 Hz range with default factory settings, but it can be adjusted to remove the shadows. Be careful, though, the wrong setting in the service menu can really mess up a TV. Here's how you do it: To bring up the "service" menu, put the TV in standby mode, then press in sequence : Onscreen Display ( the little screen with the i+ in it ) 5 ( channel number 5 ) Volume Up ( upper end of volume button ) Analogue ( middle top button ) The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it. Press the "menu" button ( middle bottom ) Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu. Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust ) Move down to "S H Pos Reg G". It should be "10", change it to "11". Move down to "SHPos Reg B". It should be "10", change it to "11". Press the menu bottom to drop out of the menus, and the standy button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
SOURCE: Sony kdf-e50a12u rear projection lcd bravia. red...shadows
try this http://www.avforums.com/forums/showthread.php?t=459681
SOURCE: Sony KDF-E50A10 50 inch LCD
It was the light engine, went bad, we called Sony, wrote a letter and they paid for it, $975. they paid all but $135(half the labor). The TV was out of warranty, 20 months old. We told them they warranty the picture tubes in old fashioned TV's for 2 years, the light engine was a comparable part, big component of the TV, so they covered it, our picture is now beautiful
SOURCE: Sony KDF-E50A10 50 inch LCD TV
I called Sony Customer Service and they put me with Executive committee, you have to be firm, we said the light engine is the major component of the TV comparible to a picture tube, which is warranty'd for 2 years on a regular TV. They were great, we got our TV fixed in less than 2 weeks. Hope this helps
SOURCE: Too much green color
My wega 50 inch TV is only 2 years old and is showing mostly a green background otherwise the same gorgeous picture!! Can you help??
