Do they make a single gang combo dimmer & GFI.
SOURCE: Richmond 500 grid dimmer switch keeps failing
In addition to an individual rating per dimmer, these dimmers have a total recommended rating based on the size of grid used. Assuming you've got three in a double box - the total combined load is 1000W of tungsten or 700W of LV fittings. It looks to me like your trying to dim too much in a limited space and generating too much heat.
SOURCE: what is the color code for a GE dimmer, 600W
Standard household electrical devices have the following color convention:
copper screw = hot = black wire
silver = neutral = white wire
green = ground = green or bare copper wire
SOURCE: 3 way dimmer in a single switch ap
Sometimes it can sometimes it can't. They make dimmers designed for both. If it is not designed for both it can only be used in a 3 way application.
SOURCE: we have the slider lutron
I don't think you can do what you are trying. The fan & light are on one circuit. Probably, originally, there was only a light fixture there. The fan/light is on a single circuit and the remote does the controlling of both units.
Now, you are trying to install a fan control and light dimmer but you don't have wiring for each separately.
You might be able to use one of the dimmer controls to adjust the output to the fan/light combination, but you can't control them individually, if I understand your wiring.
Gary
SOURCE: have a thyrocon dimmer, says on the bottom, 0180,
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Lutron shows widest selection of dimmers.
The wattages you posted are standard for multiple dimmers.
Once you identify type of dimmer, add a comment and say if dimmer is single-pole or 3-way.
A 3-way dimmer would be in a hallway, where more than 1 device controls same lights.
Single pole is where one device controls lights.
If I know what dimmer you have, I can search for the product and add another comment.
Or search for yourself:
For example, let's say you have 3-way Skylark dimmer.
Do a google search for 3-way skylark dimmer:
http://www.google.com/search?q=3-way+skylark+dimmer&ie=u
Or 3-way rotary dimmer, etc.
If information above doesn't help, then take advantage of fixya phone service.
Fixya expert can talk with you over the phone for a price.
