Follow this steps and fix it. God bless you
Secure the lamp cover and the air filter cover of the
projector body if the projector does not power on. Ensure that the power
cable is firmly connected to the projector and an active power plug. If
the projector was turned off and then on quickly--let it sit for 90
seconds before trying to turn it on.
Replace the projection lamp if the projector will not power
on or if the lamp indicator is flashing. Turn off the projector and let
it sit for at least 30 minutes. Locate the lamp cover and remove or
loosen the lamp cover with a screwdriver. Carefully remove the
projection lamp from the projector housing using the handle, if
available.
Place the new projection lamp into the projector housing and
secure it to the projector. Replace the lamp cover and reset the lamp
timer. Power on the projector to ensure the new lamp is working
correctly.
Remove the projector from the enclosed area to allow air
circulation if it constantly overheats. Place the projector into an open
area and make sure there is no blockage for the ventilation holes.
Unplug the projector for at least 45 minutes to allow it to soft reset.
Clean the air filter to allow the projector better air
circulation. Turn off the projector and unplug it from the outlet.
Remove the air filter cover and use a vacuum to remove dust from the
area. If the filter is unable to be cleaned correctly or is damaged,
then replace it. Pull the air filter from the projector and place the
new one in the now empty slot. Close and secure the air filter cover.
