FUJIFILM FinePix JV100 Digital Camera Logo
H
Helmi K Posted on Oct 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to restart lens - FUJIFILM FinePix JV100 Digital Camera
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • FUJIFILM Master 102,366 Answers
  • Posted on Oct 28, 2013
FUJIFILM Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10433576
Points
622693
1helpful
Lens error.. I have restarted & restarted camera..still same lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
2helpful
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
2answers
''lens error restart camera.''
Was the camera dropped or has it been exposed to sand dirt etc?
3helpful
How do i restart my canon camera?
Restart means turn it off and on. But I believe that you failed to mention the other words that go with this error, namely "Lens Error, Restart Camera". Sadly, restarting the camera usually does not work to correct the lens error.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 11, 2008 • Cameras
2helpful
2helpful
5answers
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
5helpful
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
1helpful
Lens Error, Restart
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 31, 2007 • Cameras
Top FUJIFILM Cameras Experts
ZJ Limited
ZJ Limited
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
