You need a router which connects to ethernet..ADSL is connected by RJ45(Telephone connection) ... Many cable companies include a router in the Modem (Verizon) others need a router to do wireless which gets connected between the PC and the Modem . the DSL-2750U is well over $2000.00.. a normal wireless router is $50-$100... a regular router gets connected by ethernet to Modem and router ,, then has 4 other connectors .. ehternet to PC.. Also requires power supply. .. wireless has to be setup for the software.
SOURCE: 360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
SOURCE: Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: 2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at [email protected]
Want to add that the internet does pass through that router to his desktop via wired RJ-45. Just that the router doesn't broadcast wirelessly.
