Problem:
Bosch Classixx WVF 240S Front Load Washer/Dyer... Won't spin.
Solution:
Recently I had problems with both washer and dryer and I decided to fix them myself.. I did this successfully..
My washer had leaking pump..
The dryer wouldn't heat..
I did the following..
I went to Google and typed in the Make and Model number. I found some info on the Maytag units so I began a note pad on what I was finding..
I would recommend that you do the same...
I found the following:
https://www.youtube.com/watch?v=wlMoT9rgvAg
The information may prove to help you but sometimes calling the repairman may be the best solution.
I listened to a couple of videos on the Bosch and did not feel that I would rely on the information.
In your case I would go to the dealer and ask him what are the most common causes of a Bosch that won't spin.
Next I would ask if they have a manual to DIY as I would like to repair this myself.
Asking these questions from the parts department is also useful if I didn't get plausible answers.
I also found the following on Fixya:
https://www.youtube.com/watch?v=qqGWjxzY-tw
These machines have a level of complexity. I trained repairman is best. If you are very mechanically inclined you may be able to figure it out, order the parts, get a DIY manual (usually availble online through manufacurer), and have fun learning... That is what I did..I fixed them both and saved a few hundred dollars at the same time learned that I could do it (that is valuable to me)..
I hope this helps you,
cmilton111
