Freezers Logo
Posted on Sep 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridge not cooling
I have a 4 year old zanussi fridge/freezer,the freezer compartment is working fine, but the fridge compartment does not get cold???it makes know differance if you adjust the thermostat.
  • 1 more comment
  • Hill16 Nov 08, 2007
    I have a 7 year old Electrolux integrated fridge freezer. The freezer is fine, but the fridge compartment is not cooling. The light is not coming on either.
    Any suggestions gratefully received!
  • Pierse Feb 25, 2008
    I have the same problem. The freezer bitworks fine but the fridge isn't cooling and its only 3 years old.
  • Anonymous May 07, 2008
    fridge part not working
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
537
Points
0
How would you test to determine which of the three
velile hlongwane
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 08, 2007
velile hlongwane
Contributor
Level 1:
Answers
Questions
Helped
4761
Points
There's possibity of a small leakage in your fridge. Refridgerant refill by your local fridge technician will help thou it's not guaranted how long it will last unless he tracks a leak and close it before refilling. If you don't do it soon your freezer will also loose coldness. Vejas
Anonymous
Level 3:
  • Master 473 Answers
Anonymous
Master
Level 3:
Answers
473
Questions
Helped
451814
Points
1483
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Freezer seems to be working fine but fridge is not cold... fridge is on top of freezer, it is a frost free zanussi, not sure which model thou, just coming up to 5 yrs old ? any help would be great thanks
A fan controlled by a thermostat is required to move the cold air from the freezer to the refrigerator for cooling. Use a volt meter testing the voltage on the fan. If you have voltage it is a bad fan. If you do not get a voltage test the thermostat. If it measures zero ohms short the thermal switch or if it is a short open one lead. If the fan works replace the thermal switch.
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 • Freezers
1helpful
Hello, we have a three year old LG GR-359SQ Fridge freezer. Firstly, everything works fine with the unit but at the bottom of the freezer compartment is a 30cm x 30cm by 10mm deep trough that in a space of...
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Jul 02, 2009 • Freezers
1helpful
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 • Freezers
2helpful
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
1helpful
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
1helpful
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Auto defrost is not working on my zanussi ice free fridge /freezer
You have a defrost problem. It means you have 3 parts that can be involve ( timer, defrost thermostat, element) most of the time it's the timer. Hope it was helpful. :)
Francois
Aug 25, 2008 • Freezers
I have an unexplained smelly zanussi fridge/freezer model Model zx99/5si? I have a zanussi frost free fridge/freezer model Model zx99/5si which is just 4 years old and it is now giving off a revolting...
Hi - we had this problem, and it was in fact where some blood from a defrosting pice of meat drained into the compressor condensation tank and began to decay!
I agree the smell is terrible, so a good clean up is needed but this solves the problem immediately!
Kind regards,
Mike
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
