Normal 0 MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:''Table Normal''; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:''''; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:''Times New Roman'';}Hello friend, I am no expert in fridge what so ever. Inquestion is jenn-air frost free model JRSI223. It works, it does not cool. From the web search I did tillnow…fen works…light turns off when closing the door…engine runs, I can hear it,but no longer can I hear that noise every now and then when soothing turns on…youknow what I mean… In the freezer at the bottom part, back wall I see some fine iceshaving typo of thing accumulated…I wiped it off… a bit of liking from thatpart as well… I assume that my ten year old daughter or I for that mater haveleft the freezer door open with a first ice cream of the season… might be twotree days that started… I vacuumed the back of the fridge where the condenseris… also just unplugged the fridge from the wall…in freezer to mention there issome cold air coming, so I think… by the research, I might be wrong, but if I resetthat defrost timer I might be ok and fright might be cooling again…problem is Ican not find defrost timer… I unscrew couple of screws from the freezer wall,but managed only to kind of peek into the upper part, as I do not know how to movethe inner wall cover, and I scared not to brake something if I **** it to hard…Cansomeone tell me where is this defrost timer…and what to do when I find it….Thanks…
You can unplug the unit & open the doors. Not very friendly to all of the items in the fridge. You can accelerate thawing w/ a heat gun or hair dryer. You will need to replace the defrost timer to prevent it from re-freezing. The defrost timer is relatively easy to replace. I recommend viewing the manufacturers' website to determine location & part number of the defrost timer.
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working. * Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover. Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer. Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor. Take care in solving the problem....
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
You have a defrost problem. The coils freeze up behind the freezer wall and the air does not flow properly. Replace the heater, defrost timer, and thermostat. get me the model number and i will give you the part numbers so you can order the parts.
