Televison & Video Logo
A
Anonymous Posted on Oct 27, 2013
Prosser I.C In my t.v damaged. I.C NO:TDA9381PS/N2/3IO955. I WANT THAT I.C
Zain Shabbir
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 18, 2020
Zain Shabbir
Contributor
Level 1:
Answers
Questions
0
Helped
104
Points
Sinck problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Blue screen error iternal_power_error acer aspire 4736Z- how to fix?
your ram or processor or co prosser main se kisi ek device damage ho chuki hain
When i press power on power supply turn on but power led is orange should be green , prosser fan works but prosser not work correctly , i put this prosser in another computer works very good rams and...
This is a problem coming from your signal cable(cable from system unit to monitor).
All you have to do is to change it.
If it still doesn't work, you have to change your monitor
Emachine W5243 keeps cutting off (stays on from 5 mins to 20) just cuts off, thats it.
chack your prosser cooling fan is not working that y your cuts off
open your case then star your CPU and keep waching your Prosser FAN you will see after some time it will stop or it wont start at all
1helpful
Hotpoint uy46 main oven over heating please advise
replace the tempt prob as if the control was bad the other oven would not respond . there is probe in each oven to tell the prosser what tempt they are running at . if one prob failes no info is sent to the prosser . ( replac it mm .. )
Powers on no pic
there are many cause for it 1/vj has gone change it to check it.2/ wp/vista progrram is damage repair it 3/ ram may be damage change it to check it. mother bord may be damage change it to check,prosser may be damage change it check. last u may change high graphic- press f8 then u can correct require graphic....thanks
Motherboad processor getting hot,new fan change,powersupply change & ram change but its still too hot plz what that problem u can tel me
install orinal fan of intel or cpucoolar .............and check your prosser is cool ...ok and all problem in mother board in prosser panal .................
2answers
Free up grade from intel pentium 3 prosser
well what do you mean by FREE UP GRADE
for a normal upgrade just follow your manual of your mother board or just go to coomputer hardware shop and ask for the latest processor they could give for a motherboard which you have (give them the model number)
offcourse they will cost you
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
